Root A Couple of GTab Rooting Questions
mtbcpa
Member
Again, thanks for everyone's help in the past. I have a couple of questions:
1. Is there a standard list of the cache clearing, etc. things to do, and a correct order to follow, if you want to be sure to have the most bullet proof install of a Rom on a gtab possible? I tend do do a bunch of things just in case, but I really don't understand what I am doing and why, and I have off and on success with stability. I would like to know of these items, which I should always do for the highest chances of sucess, and in what order, if applicable:
- Wipe cache
- Factory reset/data wipe
- Wipe dalvik cache
- Format SD
- Fix permissions
2. The most stable install I have had was Mountain Laurel, which I loved. The ONLY quirk I had was I could not find the facebook app or the twitter app in the market. Is there a fix for something like that?
Thanks!
In my experience, the most helpful are:
Wipe Cache
Wipe Davlik Cache
Format Data
Format System
I only formatted my SD card when I starting using Honeycomb ROM's, and then I had to also use the NV flash to reset my system partition as well (250MB). I've never needed to fix permissions myself, but I know some problems require you to do so.
There is a market fix you can try, listed here:
Working Market fix (tested on TnT Lite, should work elsewhere) - xda-developers
This is what I do...
Wipe data
Wipe cache
Install my ROM and if there's a new kernel
I wipe davlik cache.
Sometimes I even do the following if I experience weird things after I install a ROM..
Use the advanced options
format system times 3, cache times 3, data times 3 then install my rom then wipe davlik.
Oh and fix permissions is used when you experience force closing apps. Sometimes that helps fix that.
Ok, I have GTabComb installed and now after a month or so of stability, I am starting to experience force closes, etc., so I am considering some of the above actions. Which one of the above will make me lose data/settings, etc.? Thanks!
you can wipe cache and dalvik without losing any of your data or settings. wiping data is the one that will clear everything.
How about formatting system and formatting cache? I suppose getting rid of cache is never going to harm anything.
Formatting system and/or cache will not erase your current data/settings either. Basically, as long as you don't touch the data partition, you will be fine.
