a couple of questions...
adam_hilluk
I used to have an HTC Hero and have switched to Desire a few weeks ago.
On my Hero i had different sounds set up for my text messages and my e-mails. For some reason i just can't figure out how to do it on Desire and i really hope that you can have seperate sounds. Any help would be really appreciated. <THE MAIN ISSUE>
The second thing is that to save pictures off the internet i know that you longpress and get the options. However with google images not for some reason you can't do that :(
The alternatives i've found are to either do the usual longpress options on either the small thumbnail in google search, but that gives a rubbish little pic =/
OR
open the image and then follow link to original page it is from, then save from there.
But both of these are a bit of a faff. So although its not a big issue i'd like to know if there is a way to save from the individual pictures if you know what i mean.
Thanks in advance
Just another thing i've thought of... because i have an orange branded Desire my music player has a rubbish link to orange music world or something by the play, and skip track buttons...
any way to get rid?
in the message / email app go to:
menu > settings
scroll down and make sure "play notification sound" option is highlighted
press "notification sound" and choose a sound.
thanks alot.
Can't believe how simple that was! Just didn't occur to me to change notification sound via message settings =\ just tried in e-mail and couldn't. :o
