So I dropped my phone in water a while back. No problem, dried after a day, worked like normal. Well I dropped it in water again over a month ago. But this time it took two days to dry. After day one I figured it was toast, so I went out and bought the motion. Then after the 2nd day, the Admire turned on. But it was in a soft brick. I let it dry for weeks and tried every few days for a couple weeks after that, but still in a soft brick. I figured the phone was done.
But!, this just occurred to me.... Could my Admire be in a soft brick because I took the SD card out and put it in my motion? If the SD card had the files on it, then that would explain it.
Now lets say I am correct. I erased the files I had on the sd card. Could I just download the files again, put it on the card, and slip it in the Admire, or will that not work?
I had OA on it. If there is a newer version, will I have to find an older version? Also, what other files did I have on in order to run it? Like CWM and so on. I can look it up, as I will have to, but I am hoping someone will have the info off hand as to save me time and reading.
Any help is much appreciated as this is going to my mother (who has gone from being a tweaking homeless women to a working women in the last year. I am very proud of her), who would like to play games while riding the bus to and from work, and while living in her new apartment.
Thanks a ton preemptively
