greycobalt
I've recently switched from a Galaxy Nexus to an S4 after a couple of years. I really like the S4, but I have a couple of nitpicks and questions, and was wondering if anyone could help out.
First, the bottom buttons annoy me since my Nexus and Nexus 7 are the exact opposite. Is there any way, mod or otherwise, to switch the back and menu buttons?
Is there any way to make the number pad use a normal number tone instead of the water drop noise?
TouchWiz was ok, but it was too restrictive with how I normally use my phone. I switched to Nova Launcher and infinitely prefer it. Does anyone know if the CM10.2 is going to be using the standard Nexus layout? If so, will that fix the above problem as well?
Every time I want to connect my headset, it pops up in the middle of the screen saying paired, and I have to touch it to connect. Is there a way for it to just connect automatically every time?
The boot screens are a little much for me, and the Rom Toolbox said it flashed a new one, but it never happened. Is there a special way this needs to be done?
Thanks in advance for your help everyone!
