Help A Few problems (Metro)
Demoquin
I have had my phone since last April. I have rooted it, and installed CM7. Lately my phone will keep restarting for no apparent reason. Also, I seem to be getting no service as well in places i should be. Once i get the icon "international data roaming", i will move to an area that would get service and still nothing. I have to manual restart the phone to get rid of the data roaming thing.
I have factory reset the phone and that still hasnt fixed this problem.
In short
Phone keeps reseting periodically
No coverage unless i restart phone
Any ideas?
You might just have too much going on and are experiencing low memory problems... The Ascend can't handle very much at once. I usually avoid widgets and apps that are regularly refreshing, that tends to slow down the phone more than anything else. Also, if you have a lot of texts, you might try deleting them, at least the ones you don't need. If that doesn't help, post back here and I'm sure someone can come up with another solution.
I only have one widget for a clock. No text of. I have 3 pages of icons totaling to about 15. I dont think it would be a memory problem as i am not running anything. I do use Go Launcher though
Took off a lot of apps to try and see if thats whats causing it.
Ones i left are
Purple Punch theme (CM7)
shazaam
zedge
you tube
angry birds
GO Launcher
GO SMS
Go Keyboard
In short
Any ideas?
1) What are your CPU/GOVERNOR settings?
2) Which version of CM7 are you running?
^ Yeah. What he said. Only other thing I could think of is you just have a lazy ascend...
Angry birds is the only one of those apps I've ever had problems with. And that was just poor graphics and serious lag due to no gpu...
^^^Yeppers,the ASCEND definitely isn't known for its gaming abilities,but,some simple,less graphic intense games are definitely in order.
Just wanted to add a couple more suggestions to maximize performance w/the ASCEND.
1) Get the best SD CARD that you're willing to spend money on.
Regardless of storage capacity(16GB max for the ASCEND),get at least a CLASS 6 or better yet,a CLASS 10.
Some have a favorite brand,but,just go w/something you've heard of & you should be good to go.(SANDISK or PNY are my recommendations).
2) Try out the script V-6 SUPERCHARGER.See the thread on the subject here in the ASCEND FORUM,by SCUR,for flawless installation instructions & information on what this kickass script will do for your phone.
I have the cpu set to 245 min and 600 max
Version CM7 - Ascend - 04162011
Check out CM7 09132011 (Latest update)
Not sure how high the max CPU is in the version you're running,but,if it's higher than 600,I'd try to gradually increase the max setting to optimize performance.
The 245 low setting is what most use & is recommended,unless you're having performance issues,then,bump it up to the next higher setting.
Sometimes things just go haywire for whatever reason, and a re flash may be in order.
