A few questions?
PedjaxD
Hay,
1. Can someone tell me how to turn off "T9" in messages?
2. I was connected to wi-fi, and i put some app from market on downloading, then i lost signal, and download is now paused, how i can delete notification that downloading is paused?
I hope that you understand me, my English is bad.
Thank you.
Welcome PedjaxD, you were understood perfectly! :)
1. Settings -> Language & Keyboard -> Touch Input -> Keyboard Types -> Standard
Then Text Input and switch off Prediction.
2. Pull down the notifications bar at the top of the screen and long pressing the notification should get rid of it?
Let me know how you get on.
Thank you, i work's perfectly. :)
Edit:
I have one more question, if i understand, i can connect to my PC internet with USB cabble, and that free? Right?
Thank You.
Yeah, as long as you have HTC Sync installed on your PC. When you plug it in, just select the connect to internet via PC (or something like that, I can't remember the exact option).
Is the PC connected via WiFi? You can use your phone to connect to the same connection.
