1. Installed an application that has a battery temperature indicator. What temperature becomes too hot in Fahrenheit, any warning indicator? I read somewhere that at 120 it will overheat and may not work and charge.
2. For Virgin Mobile if you had the $35 plan with only 300 minutes, couldn't you just use google voice after 300 minutes and use the internet since it is unlimited for making phone calls? I can't be the only person who thought of this way around the 300 minute limit.
3. My phone never freezes or reboots so how often should I restart it? Would this clear the cache or how do I clear the cache? I assume that helps improve the speed. Any other suggestions on weekly maintenance are welcome.
Thanks in advance
Thanks in advance
