Root A few questions
ladyglaze
Will the thunderprop for miui 1.11.25 work for miui 2.4.20?
What's the best kernel to use for miui?
Are there any tweaks that would help improve battery life? When I'm using my phone, it seems to drain rather quickly and during these times, I'm mostly just chatting over an instant messenger or browsing the web. When it's idle though, it'll last a good while.
When I'm connected to wifi and my phone is idle for a little while, it randomly reboots. Anyone know what would cause that and how to fix it? Drives me nuts.
And lastly, where can I get the wallpapers for this rom? lol
Thanks!
Thanks!
I am currently using MIUI 2.4.20 and my battery life seems to be fine. I do not have the same wifi problem you have though. May want to try a different kernel as they have some battery saving and charging tweaks.
I've always used Austrie's Speed Demon kernel and felt that it out performed the others battery and performance wise but some other users seem to think mantera's mock kernel is smoother (I dont) ...but try them both and see what you think.
Sorry I have never tried the Thunder prop mod, so can't help ya there.
Thanks!
Try the mock kernel it helped me with the same problem.
Thanks! I'll try them out.
