A lil advice
Hi OrKo, I moved this to the Android Applications forum. If a non root ad blocker will work for a non rooted G2, it will work for any non rooted Android. Having it here is more likely to get you an answer.
I'm not sure there is a solution for non rooted and the way ad blockers work is by editing host tables.
Ah ok, well hopefully there's something out there. Thank you sir for moving this to the appropriate side.
