davidnmegan6907
Android Expert
Android.process.acore ? Getting this about every 10 mins
Fix permissions helps 90% of the time. If still not good, wipe the cache
Be careful and mindful, many people have run into problems flashing the 1300ov and then when you go to flash anything else which is less than stock voltage. Someone PM'd be on irc last night and again this morning. It was similar to the hot water I got myself into last week. At this point outside of maybe a 1250Mhz-lv Im done trying to push past the 1200Mhz window. Im honestly 100% stable with 1200-ul. Only thing that will move me off this kernel is an across the boards uvK thanks for chasing me here bud. I've jumped all over every 1 of the oc voodoos today so just wanted to make sure it wasn't anything with that![]()
Yeah even if you have a flash happy kernel day....don't forget to wipe cache each time.![]()
See thats the difference I really did try every single one of the nemesis kernels so I can say definitively I know what I do on each. Interesting to note and maybe you wanna ponder this. I am more stable on 1300sv than either 1250's. Why well the divider is higher with the 1300 so the gpu is not as OC'd on 1300 as it is on 1250, hence a fractionally better stability in 3d with 1300. Just some food for thought. Like so many here I choose the kernel most stable for me, thats 1200ul in my case, I know nitsuj17 is best with 1200lv and you are best with 1200sv.I have wiped every time, running out of charmin.
To saps I kinda over exaggerated with that I did try one of the 1250 and have now realized 1200 is as far as my phone goes, 1250 automatically freezes my phone so I didn't even think about touching 1300. I was trying all the uv lv sv for 1100 and 1200. 1200sv seems to like me.
And I haven't had anymore FC's since doing fix permissions so thanks again.
