Have decided it's time to move on from the OG. Beginning to notice a lot of my files don't work correctly with the updates. No mad about it though. Was eventual I guess. But,I figure I will send it out with style. So,where can I find guides to modding Sense? Running 4.67 because I don't like linkify in 5.07. Stock Rom minus what I have added like qs,adv. power,init.d and such. Just went smurfed so covered that along with screencapture. What I am most interested in is themes. I have searched a lot but the guides I am finding don't work for me. Not sure if it is because they aren't meant for sense or what. So any pro's out there want to point me to some guides to get me started. I know about uot but really liking the idea of d.i.m.(do it myself). Thanks in advance.
) - on my HTC One I see files with names like Mail+nonprime.apk, which I guess are them. I can also see things like HtcCalendarWidgets.apk. If you are using a stock ROM I don't know for sure how you handle the odex files - never looked into that (I've only done this with deodexed custom ROMs, where it's anyway easy to replace the files in the ROM zip with your modified ones and reflash). Since we're talking about changing system files, definitely take a nandroid before making any changes
drawables/status_bar_backgroud or something to that effect/find that png and make it transparent. May be the long way around but I think for me vs guides this will be easier. Am I in the right direction or is this not going to work?
