dantivirus
I loaded CWM via odin and now when I start my phone I get a blue bootloader screen with this:
reboot system now
apply sdcard: update.zip
wipe data/factory reset
wipe cache partition
format internal sd-card
-- Movi_check Start..!!
checksum confirmation need_checksum[0]
Not need checksum confirmation
--Movi_check already executed!!...
-- movi_checking done!...
update media, please wait
update media, finished
# MANUAL MODE #
I've tried the factory reset and it says it works but when I try to reboot it shows the Samsung logo then goes to the same blue screen. I've tried the cache wipe and get the same results. I tried reflashing CWM via odin and it says it takes but it always goes to the same blue screen. I have the Stock Rom but it is in zip format and odin won't see it.
Please, any and all help would be greatly appreciated. I just want to get back to stock rom.
edit: Yes I did try to get to CWM with the Up Vol + Home + Power it still goes to the blue bootloader.
reboot system now
# MANUAL MODE #
