Hi everyone,
I'm new here and this is my first post, I've been looking through the forums the last couple of days for information about updating my htc desire to 2.2 (which I only actually recived yesterday).
I bought the phone brand new/unlocked from mobicity. Anyway, I received the phone and sure enough it was still on 2.1. I tried search for updates and it says my phone is up-to-date, so no luck there.
So then i proceeded to use a guide i found on this forum to do the update manually, I installed all the drivers, made a gold card, then ran the update file i downloaded and away it went, untill about a min into the procces it came up with error 140, from what I read this means i have a newer bootloader, or something. version .80?
So yeah Basically I'm after some info on what my options are on updating to version 2.2?
Thanks for your time!
Brad.
p.s my current software is,
firmware version: 2.1 - update1
Baseband: 32.41.00.32U_4.08.00.09
Kernel Version: 2.6.29-3dfdf77a, htc-kernel@and18-2 #1
build number: 1.30.415.3 CL208260 release-keys
software number: 1.30.415.3
browser v: webkit 3.1
Brad.
