A little help
KarKess
Member
I was cleaning all the crap off my phone I don't use anymore and I believe I accidently removed the bluetooth software that allows it to connect to stereo bluetooth headsets. I can control the player with the headset, I can make phone calls from it, but when I try to play music there is no sound.
I was trying to reset the phone using RUU, but it reboots the phone and then says it cannot reconnect after that and the software shuts down. I can still sync with outlook, so my driver is not the issue. I am out of ideas.
Is there anyway possible to reinstall just the bluetooth portion of the rom? Or any other advice would be appreciated.
Thanks,
