flyjbaker
Android Expert
I will say that other than the initial root procedure of pushing files to the phone, I have done everything over the air....either by 3g or by wifi. It sure does simplify things. It makes it even simpler if you use "Chrome to Phone". You just find the download(ROM,fontpack,etc.) on your desktop and go to the particular page, then click "send to phone" and there is the webpage, right on your phone. Click the download file and then you will see your download icon in the notification bar. When the download is complete you can either just clear the notification and go find it on your SD Card(it will be in the "/download" on your SD Card) or you can select the item in the notification bar and act from there. I have ROM Manager and Astro File Manager. When I select the item directly from the notification bar a popup occurs and asks me if I would like to complete the action using ROM Manager or Astro File Manager. If I choose ROM Manager then it asks if I would like to clear cache and davlik,etc. and then basically asks you a few more questions and then goes right into the install.
I will admit that I have donwloaded everything over wifi just to get a clean download. I will also warn anybody that this may not be the cleanest way to do things since I imagine things could get corrputed with a poor connection. But, like I said, I have done all of my file downloading over wifi and everything has been very smooth. I have noticed that if I am downloading a ROM, I need to "babysit" the download and not allow the screen to time out. It seems that if I allow the screen to time out, I get a download "Unsuccessful" message.
Anyway, I can download and install a fontpack basically in the time it takes to reboot the phone. I also download multiple fontpacks just so I can have them on the SD Card and install whenever the mood strikes me....good luck!!!
Just remember, this stuff goes into the "/download"file/folder on your SD Card
