exgenmeikoj
Ok so for all you flashers/modders i have a small info you share.
I flashed the tbsg4 2.1v and it fixed my problem with led,lag, WiFi,3g etc.
I came from gc01 stock deodex/debloated stock kernel. And it seems there was something causing this.
I now know most deodex ROMs are not fitted for Daily use drivers. With this said i would be vary careful flashing them. (Mostly noted to noobs)
(Note) I'm not saying all deodex ROMs are like this, just ones that have some major issues and bugs, or even little bugs that causes theses little headaches.
Great work to the devs of touched by sg4 you made me and my phone vary proud!
