I've been trying to make a couple of modifications to framework-res.apk and I've been having a lot of trouble. I've bootlooped the DX2 more than a few times (and was able to recover with the recently released SBF).
I've tried making one change, I've tried signing the file, I've tried not signing it, I've tried different compression levels on the zip, all with no luck. The one time I got my apk into the phone with my change on board (I verified that it was there) my change was ignored by the phone. (I've been trying to replace /res/drawable-hdp/zz_moto_list_texture_bg.png to change the default list background from the light gray to black.)
Has anyone been successful making modifications to this file in a DX2? If so, how did you do it?
What did program did you zip it with?
What was the compression set to?
Did you sign the file? If so, with what program and key?
What method did you use to drop framework-res.apk back into the phone?
Are there any files that should not be modified? (I've heard to leave the ".9" files alone.)
Thanks,
Chris
Thanks,
Chris
