xxwckdxx
Member
Ok currently i use Lock 2.0 and use a app called power off to autorun lock 2.0. When ever i reboot the stock lock screen comes on and then the lock 2.0 loads....anyway to completely disable the stock lock screen? are there any other apps better then lock 2.0 that offer pin lock instead of pattern?
