A small update, not 2.1
Sytar
I decided to give the force update to programming a chance, and it actually did something.
I didn't get a Screenshot of the update happening, because I was surprised that it did change, but it made about 3 small changes.. One of them being the Baseband version.
I checked my wifes phone and she is still on the older settings.. I will try and run the update and get a screenshot of it, if it can.
How do you force an update?
Sent from my Eris using Tapatalk
Settings, About Phone, System Updates on 2.1
I forgot about 1.5's menu order, but it is similar. Settings and something about the phone itself, where you can check internal memory and how much is left....I think.
I did the *228. When I do the one from the menu - Settings -> About Phone -> System Updates, it didn't show anything available.
Not sure if there is a different between the two updates.
I'm thinking that this was the update they released back in December? I dunno, didn't get mine til January, and when I turned on the phone there was an OTA update available. Since then there's been no push for an update, and none available on manual check.
My baseband # matches the 2nd pic. My guess it was the original update...
