Root A smooth downgrade, so I can upgrade.... Possible?
XxXplicit
I tired installing the 2.2 update, but as many of us have seen problems have been occuring. I updated my sisters radio to the version that changed the start up screen. I didn't root the phone or apply any other update except for that one. Obviously I need to downgrade what I did to the stock. I downloaded SDK and will attempt to follow this:
The reason I ask is because my cousin did the samething, but is having problems downgrading the phone. The video seems simple enough, but after hearing my cousins unsuccessful attempt I'm worried about doing this. Basically I need some help so that I can downgrade and then upgrade this phone as smooth and fast as possible. Since it is my sisters phone the last thing I need is to give her back a brick. Is there anything else I need to download so I don't fall victim like my cousin did?
It took about 2 hours including installing 2.2, but I got it done. What a pain when all I had done was install an updated radio. At least it worked
If I rooted my phone back when it first became available (no radio, or unrevoked forever), what path should I be following to upgrade to the official 2.2? Is there a path that doesn't involve wiping out everything on the phone?
I am confused. The only thing I did was update the radio. I did not root. I viewed the video, but he quickly mentions custom recovery. Do I need to root to apply custom recovery? Not sure of the process.
Any help would be appreciated
You only need to remove clockworkmod and return to stock recovery if all you did was run unrevoked3. If you ever moved files around, installed custom roms, or anything like that you will need to follow sticky about downgrading. But if you left everything stock after you rooted, can look here for information on how to return to stock recovery.
[Recovery] Stock 2.1 Recovery Image for DI - xda-developers
Confused what your asking, If you weren't rooted and were stock why were you trying to downgrade your phone? If you were rooted, installed a leaked radio or anything else, then you need to get back to stock to accept the official OTA.
And unrevoked3 installs custom recovery when you get rooted. Called clockworkmod.
My partner got her Incredible FroYo'd before I was given the chance, so in response I ended up rooting my 2.1.1 stock for the first time yesterday, performed a Titanium backup and then applying the S-OFF patch then restoring to a stock 2.1.0 image.
From there I applied the 2.1.1 patch first then the 2.2 Update.zip which worked an absolute treat. By the end of the day the phone was as good (Titanium did an excellent job!) as when I started, albeit now still rooted and with some FroYo love. Life is good! :cool:
Not bad considering I was battling a DB Server problem at the same time - which I also resolved (Yeah, I'm that good! :D )
I should add, I've never done anything like this before so I'm rather chuffed with myself!
R
I applied the leaked OTA for the Radio, 3G hotspot, etc. Kicking myself for doing it
So based on what you are saying, I do need to use unrevoked and root, correct?
Thank you for th help
Unrevoked allows you to root and flash your device. in this case you will have to use unrevoked to flash the device. You will not be rooting your phone at all during the downgrade process.
