rjhelgerson
I'm currently running dirty unicorns 1.9 (the very latest one).
I'm h-boot 1.04. Obviously I'm S off. With every update I install I encounter the same problem.
My MMS will work for a good 24 hours. Then...It hangs on (sending). I basically use MMS for one person, so it's not a "different network" situation.
Now I've done full wipes on every update of dirty unicorns. I've installed the rom and gapps, reboot, set it up.... In my Build prop, the proper two lines have been added. Yes I've checked my spelling.
I have rebooted my phone into recovery and added the mms fix and rebooted.
Now... Like I said, for every update of Unicorn, MMS will work perfectly for a good day....Then.... grrrrrr.
Occasionally I reboot into recovery and wipe cache and dalvic. That helped once...Once..
Any thoughts?
Any thoughts?
