By rooting and installing a custom ROM such as CyanogenMod or OpenDesire or Defrost you should be able to wake the phone up with the trackball however there is also a kernel patch out there for Sense that disables the power button for wake and enables the trackball (also needs root).
Not so sure about that, however if you look at teppic74's pre-rooted Sense rom over at XDA's Desire forums, he has an init.d version which allows custom add-ons and I think that patch works with it.Ok, suppose i have to root my desire then. Sound like you're saying one can root and keep the the android/sense ROM (and then patch it). Nice, i didnt know that.
Yes, you can keep Sense and root and have all sorts of other goodies you wouldn't otherwise get by installing a custom romOk, suppose i have to root my desire then. Sound like you're saying one can root and keep the the android/sense ROM (and then patch it). Nice, i didnt know that.
Widgetlocker allows you to unlock the phone with other buttons. No root required.
Is there a way of doing flight mode without
Power button too? I use it at night so not disturbed
Cheers
Dan
So does LockBot(Free)
How exactly? looked in the settings but cant find anything that relates to this, I have to press the Power Button then the Lockbot screen comes up![]()
Am I the only one who likes the way the screen is locked and unlocked? Makes it almost impossible for it to come unlocked and ring someobdy on your pocket.
