andriodadmirer
HELLO THIS IS ANDROID ADMIRER AND I FINALLY GOT MY HANDS BACK ON
ANOTHER COOLPAD 4G SO I THOUGHT I WOULD TAKE SOME CHANCES AND THEY PAID OFF.
THESE INSTRUCTIONS I AM ABOUT TO GIVE OUT ARE NOT FOR NOOBS OR ANYONE WHO IS NOT GOING TO PAY ATTENTION TO THE DETAILS WITHIN THIS PROCEDURE.
****I THEREFORE AM NOT RESPONSIBLE IF YOU BRICK YOUR COOLPAD WHILE DOING THIS
SO LET'S GET STARTED
THE MAIN REASON ANY OF US WANT TO HAVE A CUSTOM RECOVERY
INSTALLED ON THIS PHONE IS SO WE CAN INHANCE THE PHONES
ABILITIES AND BRING THE DEVICE OVER THE STANDARDS OF WHICH IT
WAS GIVEN TO US IN RIGHT ?
WELL TODAY I WILL BE SHOWING YOU HOW TO TAKE THESE DEODEXED STOCK FILES AND REPLACE ALL THE ODEXED FILES WITHIN YOUR PHONE RIGHT NOW
THIS IS WHAT MOST OF US NEEDED SO THAT WE COULD THEME AND CUSTOMIZE OUR COOLPADS THE WAY WE WANT THEM
SO TO DO ALL THIS YOU NEED
1. THE DEODEXED APP AND FRAMEWORK FILES FROM HERE...
http://www.mediafire.com/download/qmrvmk4hahgwxhu/CP5860E.zip
2. A FILE EXPLORER (I USE ROOT EXPLORER)
INTALLING THE DEODEXED FILES INTO YOUR ACTIVE DEVICE
1 FROM YOUR PHONE USING THE FILE EXPLORER
FIND WHERE YOU HAVE THE APP AND FRAMEWORK FOLDER
FROM THE COOLPAD ZIP
SELECT THE APP FOLDER FIRST BUT*********(((((( RIGHT AWAY YOU NEED TO DELETE THE SUPERUSER APP FROM THE FOLDER BECAUSE PASTING THAT OVER YOUR EXISTING SUPERUSER WILL CAUSE YOU TO HAVE TO UPDATE YOUR SU BINARY <<<YOU CAN >>>> ***BUT IT'S JUST A PAIN TO HAVE TO !))))))*******
SELECT TO MOVE THE WHOLE FOLDER INTO YOUR "SYSTEM" FOLDER
GOTO THE LOST AND FOUND FOLDER AND OPEN IT AND PASTE THE APP FOLDER INTO IT ******THE ONLY REASON I USE THE LOST AND FOUND FOLDER IS BECAUSE IT'S EMPTY ALREADY **********
NOW GO INTO THE APP FOLDER YOU JUST PASTED AND WITH EVERY APP STAT TO SET PERMISSIONS
LIKE THIS
SET EVERY ONE OF THE APKS WITH PERMS LIKE THIS
ONCE YOU GET DONE WITH SETTING ALL THOSE APPS TO THE CORRECT PERMS THEN SELECT ALL OF THEM AND THEN SELECT TO MOVE THEM ALL
NAVIGATE TO YOUR LIVE APP FOLDER AND THEN PASTE ALL OF THE APPS INSIDE
YOU WILL NOTICE ALL THE ODEXED FILES INSIDE THERE
YOU CAN NOW GO AND DELETE EVERY ONE OF THOSE ODEXED FILES INSIDE THE APP FOLDER BECAUSE YOU JUST PASTED THE EXACT SAME STOCK APPS INTO THAT FOLDER.
NOW THIS IS DONE ****
SO NOW OFF THE THE FRAMEWORK FOLDER
SAME THING HERE......
GOTO THE LOST AND FOUND FOLDER AND GO INSIDE THE FRAMEWORK FOLDER
START TO SET ALL THE PERMISSIONS TO ALL THE JAR FILES INSIDE IT
SO AFTER THIS, SELECT ALL AND MOVE TO YOUR ACTIVE FRAMEWORK FOLDER
THEN PASTE
THEN YOU NEED TO DELETE ALL THE ODEXED FILES IN THE FRAMEWORK FOLDER
AFTER THIS YOU ARE ALL SET
ONCE YOU REBOOT YOU WILL FIND THAT KILLCMD****WHERE I GOT THE ROM FROM
ALSO THEMED THE FRAMEWORK A LITTLE FOR US SO WITH OUT THESE FILES NONE OF THIS WOULD EXIST
THANKS KILLCMD!!!!!!
I DID THIS METHOD MYSELF
I HAVE DELETED A MAJOR AMOUNT OF THE STOCK APPS AND EVEN THEMED THE COOLPAD WITH UOT KITCHEN
I HAVE EVEN INTERGRATED SOME APPS INTO THE SETTINGS.APK FOR MYSELF
AND IT WORKS LIKE A CHARM
ON A SIDE NOTE ((((((((#####WHEN YOU FIRST PASTE THE "APPS" INSIDE THE APP FOLDER
YOU MAY BEGIN TO GET APPS FORCING CLOSED ON YOU
SO JUST REBOOT THE PHONE
I HOPE THIS HELPS US A LITTLE
LIKE THIS
THEN PASTE
