Root a2sd fails. Help?
auzreal
when I turn on the terminal emulator, I type sun, it allows permissions, then when I type the second command it fails. So I skipped that and went on to metroff, then a cm7. Why does the a2sd fail?
I don't type sun, sorry, that was supposed to be "I type the second command".
