app2sd is that what you're referring to?
Just use Link2sd. More stable, better increases, and the ability to do even more with it.
As for the stock application I've used it on the connect, and it seems to work just fine...IF that's what you're talking about.
If not, then I'll look into it.
email me dracconusg@gmail.com and I'll give you a link. I don't want to do anything on these forums that will be potentially frowned upon. Even if PM's are private, it's still something that could potentially cause the site, and or it's members to be at risk and it's just not worth it.
