Hey frndz i created 512mb sd card partition using a2sd And it is running successfully. But how to see the space i used in 512mb. And how to view them using root explorer, i mean the path to paste files. Am using cm 6.5.7 rom
plz some one help me...
Your phone cannot by default see the second partition on your SD card. Why did you create the second partition? Is it to install apps or to store files? I have partitioned by 8GB memory card and created a new 200MB partition for apps. But I cannot use that partition for storing any data, it is reserved solely for apps, just like internal memory. I cannot see the second partition through explorer or any other app, but I can see which all apps are installed and how much space is occupied through an app "Link 2 SD" which is the app I use to move apps from internal memory to the second partition.
