Root a2sd+ question
qiang
Hi,
I flashed my desire with oxygen 2.2.2 few weeks ago and thought it had a2sd+ support but it doesn't. I already have ext2 partition by using gparted. With 50+ apps downloaded and installed since the flash, I got only 18M left for internal storage as seen from freespace. today I just flashed with darktremor 2.7.5.3 Beta 04 and still left with 18M internal storage.
update:
run `a2sd cachesd` and got free internal storage to 88MB.
another question is that.. I am seeing 14 apps listed under the 'on sd card' from manage application. 1 of the app was installed after a2sd+ and 13 were before. why are they on SD card instead of the internal storage?
Q.
some apps auto install to the sd card, just go to manage applications and move to phone. nothing to worry about,
