I have VR13 running A2SD. I was about to switch to new Elelinux 7 v2.9 but idk if TB will do anything or if there's a new way of getting my apps back after flashing a new rom. What do I do to restore my apps AND still have A2SD running after I flash it? Thanks.
Just make sure you have the ext partition and a aps2sd enabled rom, that's about all you need. It doesn't make any difference to Titanium where the app is; just backup as normal and it will restore it into your ext partition if you have one.
