Root A75_Stock_Updated_2.3.5
drdogautam
hi all,
I have a ROM with video calling feature and all other features of our stock ROM thats why I named it stock_update of A75. :)
Screenshots of new ROM are in 3rd POST.
Features:
* Swap support
* Energy smart mode to save battery.
* highly Customizable UI
* Lots of Themes.
* New Dialer & Contacts app : fast and gud looking. :)
* Super fast ROM (without any script)
* 8 MP Auto focus Camera.
* superfast internet (i have used wifi network, but speed is fastest in this rom as compare to others... Note:i have used lots of ROM before :D )
* Call Recording facility in the dialer, no need to install any other app.
* Call & SMS blocking feature. ( to block unwanted peoples :D)
* Wifi hot spot feature in one click. (far better than wifip2p apps in stock 2.3.4 version)
* App lock facility to make any app un-killable.
* Privacy guard to protect ur phone.
* anti-theft feature.
* wifi/data monitor.
* ongoing service diplayed in notification bar.
Link is here:
https://adf.ly/REtyg
Mirror:
1. https://adf.ly/REu72
2. https://adf.ly/REuAn
waiting for ur Feedbacks.....
Update Account And Sync Settings Tab For all those who aren't getting the Account And Sync Settings here is a fix for it just flash it via recovery and reboot you will get the Account And Sync Settings tab in the Settings. If after flashing you dint get the tab in Settings then just open the system/app in root explorer and go to AccountAndSyncSettings.apk and AccountAndSyncSettings.odex file and then just give the permission as r-w-rr and reboot. If still you dint get it then report here.
Enjoy...
swap support? ??????
btw I have that rom that is lenovo a300,,,which is similar to a60 stock rom,,,,
swap needs boot.img needed to be edited????
that lenovo's boot.img will not work on our phone
I think we can change the theme in settings of this ,
hi all,
Features:
* Swap support
* Lots of Themes.
etc etc...... :D
swap suppoted ?????
are u sure .
try ram expander or replay me its work or not :-)
Waiting for the download link and yes if the swap is supported then it will be a great achivement for our phone which will give a new hope for having some faster ROMs on it so buddies who ever can work on boot image and knows to edit it please edit it and make it swap supportable please.
its ok...sai have this ROM...so no need to upload it.... sai can provide the download link ;)
yes swap app work on it..... but i have not used it yet coz i m afraid by its warning that "Swap function may damage your SD card" and i dont wanna loose my 16 GB Class 6 SD Card. :D
I need a tester who is willing to damage his SD :D.
Bro no reply arent these not that ROM or else you are uploading the ROM for the newbies please reply so that i can know if you are uploading then i will wait for the downloading link else if any of these two is the same ROM what you have then i will download that ROM so please let me know.
Okay then will wait for you Download link... :( Either you can provide the link of the ROM you downloaded???
PLEASE PLEASE PLEASE provide the original ROMs link.
First is this your Rom, and why post it if you can't post links to in until days later, I would simply create the thread when you have all ready to go. Now you have a bunch of impatient members and questions. Please provide more info on this Rom, whether this is your Rom, someone else Rom, is it a new release or an updated Rom, please advise. I don't have this device, simply want to make it clear to all the members here.
yes its mine ported ROM..... i will upload the ROM by tomorrow.... I was busy in some important work....so no time for upload....
link has been added for ROM..... :D
