Help About Kernel Tweaking
What tweak are you using that becomes untweaked and needs to be retweaked every tweaking hour? :D
Most will remain until reboot. Try Kernel Adiutor.
I use the light and heavy kernel tweak options that i would change every hour.
Does kernel adiutor need a reboot every time i would tweak the settings?
You can set Kernel Adiutor to apply settings at boot. I've never used L Speed before. Are you using the stock Kernel?
