Root about to flash rom help
snowwhite
Ok so i have made a backup with clockwork made a backup with titanium made a 1gb partition on sd card moved all my apps back to phone made a copy of sd card on pc and moved leedroid with apps2sd zip to root of my sd so wat now thanks in advance after doing this once i should get it lol is having 100% bat neccessary im at 75
Thanks im running leedroid 2.3d awesome only thing is add free needs updated and how do i got about customising it it has launcher pre installed wanna try not use sense for a while so i can update to gingervillian cool status bar and theme with icons will do
Is AdFree working for you?
If it's working, leave it as it is.
If it isn't, uninstall AdFree, reinstall it, clear the cache and reboot.
If you want to use the Launcher, go to Clear Default Home.
Want to use launcher but want themes i rekon il jus use theme kitchen addfree didnt wrk so i uninstalled it and dl it again frommarket perfect now
Chances are LeeDroid comes with the older version of AdFree that needs S-OFF - newer ones can be symlinked to the SD card and works fine
Yep its not been working until recently.
All I had to do to get it working was to download the updated version from the market - prompted to update as soon as I went into the market after flashing rom. Didn't delete the old one, didn't delete data/cache.
