access to sim in x10 mini pro and more
igal.ep
Hello everyone,
Recently i purchased a x10 mini pro, and I've some issues with it
First, i can't access to my sim card, i did imported all contacts to sim, and the phone does works (sim recognized) but i can't copy/edit/delete contacts within the sim card (i downloaded Contact2Sim app from the android market), when i'm trying to launch the app, i get an error message which says "Cannot access SIM card. Pls make sure that a SIM card is inserted and ready"... any idea for the solution ?
Second, is there a way to set auto email check ? (i mean auto synchronization with the email account which i imported' my gmail account, cause it's synchronized only when i'm the initiator of the operation...
Thanks
I dont think that his reply was serious..
Anyway there are known problems with SIM cards and X10 mini (pro).
try contacting your carrier about a new SIM card (with the same number of course) that is compatible with the x10 mini pro :)
the problem is, x10 mini pro doesn't supported (yet) in my country
hi igal.ep! im having the same problem too! when i was still using 1.6 i was able to access my sim card thru setting>sim card. but when i updated to 2.1, i cannot see even single message from my sim card. can you tell me how you solved your issues? thanks!
hey,
I didn't move to 2.1 yet, i'm waiting to root for it
