Guba
A very strange thing happens to me.
I insert a pendrive (FAT32 formatted) in the USB interface and (correctly) it appears the USB icon in the status bar.
But if I try to find the USB resource in the file system with different browsers it is impossible to be found.
Where is the files location in the filesystem tree ?
The same is for the files on the SD card. It seems that these files are visible only via media-players, but not in any other way.
I looked for these infos on the manual but it seems that the writer wasn't in the right mood for some good explanation...
Thanks in advance for any help.
Guba
Guba
