Accessories Accessory Questions
vaterp99
Three questions for you:
Does anyone have a good recommendation for a cardash holder? For mounting to windshield to use as a navigation tool?
Does anyone have a good recommendation for what case is best if I'm using the phone as an audio player while working out? I have an armband case for my old ipod - something like that would be great for the gym?
I know its been asked a million times as well - but what about a regular case? I am looking for some safety from drops, etc, but I dont mind putting it in my pocket as well... if anyone has a good rec....
thx!
1. While they are a bit spendy, I have been using a ProClip car mount for the past 2 years and love it. It is literally made to fit your vehicle. It holds the phone very well due to the fact that the holder is also made to fit your specific phone. When I got my Inspire, I had to change the holder to their adjustable one because I have a case (see #3) on it.
2. I really don't know. I use an iPod nano when working out.
3. Check out Seidio products. I am using the "Active" case and love the way it fits and protects. I also have a Skinomi screen protector.
Have fun!
I have not used the full skin protector. Probably because I don't have the patience to line up all the pieces. I will say that their screen protectors are the best I have ever used in the last 10 years or so. They have absolutely no orange peel effect and if they get a scratch in them, they heal themselves within 24 hours back to looking brand new.
