Accessory Recommendations
PKayy
Member
I'm looking for a case and a spare battery charger and recommendations for any accessories that you found useful!
I just ordered that charger and spare battery last night. I also ordered the Motorola car charger that is supposed to put out 950mA. I didn't see specifically where it says the battery is NFC capable, but the pictures look like the right one. I also bought some NFC tags to try out.
For a case, I really like the standard holster right from Verizon. It is thin, unobtrusive and has a built in kickstand.
one more thing about the holster. When you're holding your phone, slide the kickstand out and slip your third finger through it. It makes it easy to hold and thumb your way around.
