Help accidental mutli-texting
traajik
Has anyone had their phone send the same text message two or 3 or 4 times just by hitting send once? It's starting to happen more and more frequently, i have flashed the phone before i dont think it has to do with the rom i'm using, but could a bad flash be the culprit? Every thing else on the phone works including a 13 hour lifetime per charge.
13 hour sorry you have wrong phone unless you have ex BATT
and what ROM your using and just SMS or MMS
and yes that right if you send mms and data is low or jumpy it will send to think it failed then but in outbox and resend it again and the same go for SMS
It can. It depends on where he is, and whether or not he has 4g on. With it off, you can get up to two days of battery power, and if it's on in a location with strong and stable 4g, you will get half a day if syncing does not occur often. It's in locations where 4g is intermittent that you'll notice the most dramatic drops in battery life.
ouch! that's terrible!
I am on the stock battery, and never see such drastic battery life...
Sorry mate.
Have you tried reconditioning the battery and clearing the battery stats? Maybe that might help... :-/
even with Basix rom it dosent last 13hr on standby
that sounds pretty familiar, maybe 4-6 hours or so for the first cpl months when i got it
and no not new i got it back in may or when ever it came out.
I get at least 8-10 hours of good use out of it per charge depending on how many things i have/keep open. 14h42m somthing was the highest i've seen, roughly 13 these passed couple days.
p.s Ah yes 4G, mine is always on and i'm always using it (i never shut it off manually, and only lose it when i go into underground parking garages) unless i'm using wifi.
also if anyone doesn't have the wifi tether installed and has a computer in the car you most defenitly need to install it
