Accidently deleted my mtptemp files. please help
spetzie
I was cleaning out a few misc files from my s4 that I know are safe to delete and I must have selected my mtptemp files also by mistake. Are these needed. What do they do. Please help.
I think you'll be OK. As their name implies they are temporary files. The app or processes that users them will regenerate them if they are needed.
Yea youre fine, really as long as you dont delete anything that requires root to delete, you should be fine. You may lose some data but nothing too major other than that. But this is a temp folder, it will be recreated if needed, nothing to worry about
