Root accidently deleted play store on prevail, and need help!!
kskillz
I deleted the play store by accident, and need help getting it back. I tried dl many versions, but it starts to load and freezes thus making it impossible to use. My phone is rooted btw any help is appreciated, thank you!!
Go back to the galaxy prevail forum and I posted it there for someone else I don't have it now. It's in a thread that says play store or something . Sorry I don't have the info right now I hope that this helps you, play store not downloading for me
I tried your version and no luck. Still getting the same error "The application Market has stopped unexpectedly. Please try again....still need help please
With mine you need to delete the data then uninstall that but you already did and then mine you flash in clockworkmod
thanks guys, I loaded this version, and it loads, but now i get an error when trying to update my apps. Any idea what I may be doing/did wrong?
Edit: Actually its not working now either. Anything I can do to bring my play app back?
what rom are you using? might have to do a reinstall!!
this is what im using PREVAIL_M820_FA19_Rooted_CWM
i hope not but if so it wont be the first time.....:(
ether try again , make sure to wipe data for market and then uninstall, then flash that again and then let it upgrade and if not might have ti reinstall rom???
if you don't wipe the data it will just put the bad back on new install..
Here's an older market that I made CWM flashable. Flash using CWM and it will update after you sign in. Make sure that you wipe the data from your preexisting market and then delete it before installing this.
CWMmarketInstaller.zip
just curious if anybody know....
my busted @ss intercept has play store 3.5.19 (manual update from 3.5.16)
but prevail always 3.5.15 won't go up manually (ctmod 3.6)
is this because intercept is 2.3.7 and prevail 2.3.6? and if so why we not 2.3.7
I've had intercept, fascinate, ascend, all 2.3.7. only difference I can tell is prevail won't change .db to wal in titanium but intercept will lol
Ty I'm going to try and will let u know how I make out.....im just going to start over.....nothing i tried worked :(
