Help AccuWeather not updating
Phoenix1974
Anyone else having a problem with their AccuWeather widget? Mine shows the right date but it will not update the weather and hasn't done since the 4th.
I guess you're having the same problem then
No problems...everything is up to date, at least as of the time I posted. However I have been using Weather Bug Elite, and Launcher Pro for the past week, so I can't confirm if accuweather was being updated properly.
Sorry I thought you were having problems too as at the bottom of your screen shot it says last updated was in June, just realised that I was reading it as UK date lol
Go to the app/widget and press menu -> settings.
Make sure Enable current location is checked
Set your Auto Refresh to what ever you want
Also make sure your GPS is on as well
I was having the same problem with the widget not updating. After I cleared the widget data and cache (settings-applications-all-weather widget main) it works again.
I use weather bug. It updates fine but isn't user friendly nor intuitive at all.
-Sent using the force
Sometimes launchers will do that. Apex will not update any Twitter widget i use. Holo has no problem with that.
