1. let everyone else do the upgrade first. Gingerbread is a well established stable OS. If there are going to be any problems, then lets someone else, and not you, find them all out and wait till all the bug fixes have been done. You don't need the hassle.
2. More importantly, the newer OS will I expect use more ram storage and more CPU time, just like newer PC OS's seem to. It will scroll better etc and so on...... It will no doubt have lots of newer 'features', most of which most people probably won't use.........
And as a result all of the improvements, it is going to do exactly what to the useable battery time?
Yeah, it will reduce it, well what a surprise there.
Enginering rule No 1 applies here - "if it ain't broke don't fix it."
