Root [ACS]Root for Transform Ultra
I'm thrilled, I just Rooted my Samsung Transform Ultra! :)
I bought it on Black Friday for cheap on the internet, and I activated it 2wks ago. I really like the phone, but already there are some things I'd like to change...
For starters:
> Tethering
> Remove Adds
Now I need to find a way to Root my kid's cell phone.... LG Optimus V
Is there a one-click method for that phone too?
Love the pirate droid icon for su. Was severely entertained by the install. Dev with a sense of humor. Seems t work the business. Definately gives me the confidence in ya to try Star Scrom.
Star Settings has me drooling.
To few paychecks since Xmas but expect some love from this way soon.
is anyone else having issues loading drivers correctlly on win 7 64 bit i just cannot get them to install correctly any help would be greatly wanted
do we have to have adb installed and working prior to using this or will it just work also do we need the sdk tools and developement kit and all that i see adb in the zip just didnt want to mess up my phone before i got cwm on it and made a back up . thanks in advance . not new to android just new to transform ultra . i run a fully modded intercept now
edit : i ran both the cwm install and once click root both worked great thanks . Look for some love in form of donation from this way thanks again.
A couple quick questions:
1. Does this make the device "s-off"? Or is it just a partial root?
2. How do I find the bootloader on this phone? I pressed vol up and vol down and power and I got a screen that says downloading and something about start download now or restart phone...I didn't wanna mess anything up til I knew for sure, so I restarted...this my first samsung android phone so I've never seen that before...
-BMFC
-BMFC
our phone dont have s-off and it is fully root after you install this program. our phone dont have boot loader either. you can access to recovery mode by holding vol down and power button down when the phone is off. After you install this, i recommend you to install cwm after this. clockworkmod help you back up your file and install custom rom :cool: after you install Cwm it will replace recovery mode and you can access cwm by holding vol down and power button when the phone is off.
Ok...guess I don't understand how an android phone doesn't have a bootloader...yeah I know what clockworkmod is, I'm not new to android, just new to this weird samsung phone...so if there is no bootloader then what is the other screen I found? Its VOLDOWN+CAMERA+POWER and it says something about installing a custom OS and asks if you want to download a custom OS (vol up) or restart (vol down). If I press vol down it restarts, but if I press vol up it doesn't seem to do anything...it just seems to freeze and then I hafta pull the battery to restart...
Anybody know what its talking about? Sorry to thread-jack but my original question was relevant here...
-BMFC
I am currently using Samsung transform ultra thinking about root but i still have some major questions i'm not a rich kid . my phone has lot of apps and so on like go launcher, go locker, and so on so it has its slow moments and so on i also would be using a laptop windows 7 Intel core . wondering if that made any differences also i would pretty much be dumped with out my cell {long distance}so if anyone has some input would be very much helpful in my decision my Skype is "tylerdaly16" yahoo is "tylerdaly13@yahoo.com" please and thank you look forward to your input .... btw im on boost.
Is it possible to root this machine (the samsung transform ultra) without a pc? That's all, curious is all. Cheers!
i know there are some phones..a few htcs i think that can be rooted from the phone..but currently i dont think you can root this phone actually from the phone
i have a boost transform ultra and have been rooted since the guy s first posted the link THANKS
but device was loast and had to start over. no problem
rooted under a min
ok
everything fine a ok
then day before yesterday several apps started crashing over and over and pover you get the point this all started OUT OF NO WHERE
ummm i couldnt figure it out
tries updateing things
nope
then i couldnt even get the wifi teahter app to work
dont know why
so
nothing was working
so boost recomended a ##rtn
and things looked like it ewas okre rootinig but it says
some same apps where there now everything
it seemmed as if the root was still there
\butt guess what it wasnt
i went tio go use a appp that need rooting adn it says i dont have root i have tried and tried and tried
the rooting app says
OCR for Transform Ultra
Using zergRush
(All credit for exploit go to the creators)
One Clicks Done by
Interdpth and Shabbypenguin
* daemon not running. starting it now *
* daemon started successfully *
error: device not found
Wait for phone to reconnect...
mount: permission denied
1397 KB/s (4292 bytes in 0.003s)
chmod: permission denied
/data/local/tmp/rootsetup: permission denied
rm: permission denied
Copying files onto phone...
failed to copy 'su' to '/system/xbin/su': Read-only file system
failed to copy 'Superuser.apk' to '/system/app/Superuser.apk': Read-only file sy
stem
failed to copy 'busybox' to '/system/xbin/busybox': Read-only file system
failed to copy 'remount' to '/system/xbin/remount': Read-only file system
Setting permissions...
Unable to chmod /system/xbin/su: Read-only file system
ln: permission denied
Installing busybox...
/system/xbin/busybox: not found
Cleaning up files...
please help me
i can give my phone number and email addy to whom ever can help
thanks guy/gabbi
I want to thank all the devs that were involved. My wife just upgraded to the Transform Ultra and the root went smoothly. Thank you!
I have attached a screen image of the errors put out. Any idea where I went wrong rooting this phone?
I have rooted others successfully but this one wont go.
Oneclick for all OSs!(Windows, Mac, Linux)
Download the One Click Root!!! Run the .bat file if on Windows, or the SH file if on mac/linux
If it doesn't work for some reason. Reboot and you'll have root.
Samsung drivers if needed -->Drivers for Windows!
Thanks to the creators of zergRush
Enjoy your rooted Transform Ultra!
I don't mind donations and neither does my bud ShabbyPenguin.
APK for phone, and an How to video soon!
Link for root! run.sh for linux/mac and .bat for windows!
Owning Boost phones since '11
If first link isn't working properly, use me.
The exploit did not take. Did you retry a few times? I had to retry it a few times for the exploit to actually take.
