D desmonb2 Lurker Nov 22, 2010 #76 i entered " adb devices " and then it dosent list any devices i reboot the phone and then try again and it dose the same thing HELP PLz
E emj_wafa Lurker Apr 5, 2011 #77 kudos guys! superb!!! i had this problem and was able to make my g1 work.. love my g1 it was my first android phone... now im using galaxy S thank you thank you..
V Vysetheidiot Lurker Apr 20, 2011 #78 Hey guys, I just used this guide to activate a G1 that my friend gave me. I was wondering if its ok for me to update the phone or is that a bad idea?
Swizz Android Enthusiast Apr 23, 2011 #79 Vysetheidiot said: Hey guys, I just used this guide to activate a G1 that my friend gave me. I was wondering if its ok for me to update the phone or is that a bad idea? Click to expand... Just don't factory reset, and you'll be fine.
R Roy073096 Lurker Apr 27, 2011 #80 It says Unable to start/stop WiFi, i wiped the phone several times and updated the phone to RC29 several times. No luck.
G governa Lurker Dec 3, 2012 #82 I am stuck at step 12 I dont know wat to do when told to navigate to adb folder
