'Active' car dock for Note II
I currently have the original note and am planning to upgrade to the Note II.
For my note I currently use the Samsung ECS-K1E1BEG car holder, which has built in USB and Aux out connectors for charging and connection to the cars audio system. I have heard this type of dock described as 'active'
Are there any similar car docks for the Note II? Samsung do not seem to have created on for the new note and I would like one if available.
There are a couple option I know of:
1) ProClip makes a powered dock, but no aux out. You need to put the head phone jack in manually if you want to use aux out.
2) iBolt is "apparently" making a powered mount. It may have aux out, but don't know for sure. Some of their models do, some don't. I don't know of any other powered mounts.
I don't have mine yet, but aren't the Note 1 and 2 close enough to the same size that you could use the same dock for both?
