Active wallpaper question
rpoosua
Hi,
I'm new to Android and I have question on Active wallpaper on Moto Atrix. Does the Active Wallpaper is located locally on your handset or else where. I'm just curious if this is going to rack up data on your Atrix w/ AT&T?
Thanks!
The only data you'll rack up is if you download it. If you do this over wifi, it will not. And yes, the files are on your phone.
UNLESS, now that I think about it, you use a live wallpaper that requires data updates. I saw a livewallpaper that uses google maps. THAT will use up data if you're moving around a lot, as it will need to update the map data.
I think your right about this, but since its LOCAL then its not UPDATING any data and the only thing is that what he said about draining the battery (No worry about battery here cause we can pop in another one).
Thanks!
