Root ACTUAL timescape UI on A70..
sunil90
No, in case you are wondering.. this is not a UOT theme..you will not get your lockscreen messed up if u flash this..
IMPORTANT : TAKE A NANDROID BACKUP.. I AM NOT RESPONSIBLE IF YOUR DEVICE BRICKS..
This is the actual Timescape UI, launcher and widgets for our A70 ported by me
I used the drawables from Xperia Arc, Xperia X10, Xperia Mini & Xperia X8 and compiled them into a single framework...
Launcher and Widgets are actually from Xperia arc ported to HVGA
New link : XperiaThemev1.2.zip
EDIT:Post bugs if u find any
HOW TO USE :-
Copy the theme to the root of your SD card
Reboot to recovery
Make a nand backup ( optional but recommended)
Select choose zip file to install
Select the zip using vol buttons
Flash it
Reboot
No, in case you are wondering.. this is not a UOT theme..you will not get your lockscreen crapped up if u flash this
I used the drawables from Xperia Arc, Xperia X10, Xperia Mini & Xperia X8 and compiled them into a single framework-res...
Still have to port lockscreen and menu background (and im very close to it :P)
Here is the link
More themes coming up.. I m thinking of making a Motorola Droid theme for HVGA.. Post some suggestions on what my next theme should be :D
Wicked!!!!!!!
Superb!!!!!!!
Will continue this forever but can you change the battery icon.
Its simply superb.
superliked it.
should I add the stock timescape sound ? or should i leave it as it is ?
@monu92
Iphone UI looks great IMO :P, will see :P
if anyone wants the default wallpaper, check here
@varun.chitre
you can use UOT Kitchen to mod it to your liking :).. although becareful, it will mess up ur lockscreen..
OR if you are a little adventurous, decompile the framework-res.apk located in system/framework.. replace battery icons in drawable-mdpi folder and recompile it (using 7zip)..
@varun.chitre
Will try.
Thanks.
It is running out of memory.
When I open an app and exit it the timescape is filly blank and after few second icons start coming.
any solution?
I think it needs more ram.
don't know why but everytime i try to flash these mods my phone switches off at boot animation :( :(
none of the mods worked...:( :(
running assevmax
any solution???
whoolla. great work man
but there's no cusmisation button I mean the preference button if u can add it
BTW great work
if u can port HTC sense some day.
i'll'b'w'ing
You can create a sense theme ..but not seense ui it requires. High memory it is I think 50-60mb with widgets
yes the launcher does not have any preference button as in ADW or LPP..
There are 2 different launchers
one of them has 5 home screens .. the one i put in my theme zip file
other one has 3 home screens.. link here
Use the one u need ...
Still working on Lockscreen and Menu background ..so u all will have to wait a bit for next theme
EDIT: Found a bug.. the carrier font is black .. have to make it white
Hey timescape goes out of memory. when I exit an open app and go up homescreen then it is blank in the middle as well as the corner rounds.
After few seconds the icons in them start coming back.
How to solve this problem??
well dude I reverted back to go launcher cause ur ui doesn't have much custemisation in it
But lol my notification is still sexy blue ,battery icon and the edge icon they are all damn same thanks a lot
just can't read the operater name properly but doesn't matter I know which sim I m usin
great work
+1
@varun.chitre..
yes i noticed that problem.. it only happens when large apps like dead space or Nova are opened.. Ill try to do something about it but i dont think this can be fixed easily..
@manish9009
ill fix the operator name shortly..
@varun.chitre..
@manish9009
It happens also with gallery,uc browser, phandroid app
