did you figure out how to get the adb working?? mine is driving me crazy im trying to get it to install the system apps that i accidentally removed without backing up. somebody please help out
I am having driver issues also.. A workaround I found was using the app adbWireless over the wifi connection.. even had to flash cwm with it.. also, make sure usb is set to internet connection for standard adb..
