ademidio453
yea I can not get this to work either and I'm pretty good with computers which is why im so frustrated....can someone help explain this a little more clearly...The "*daemon started" does not show up at all, but It does list my device ID. I can't get this to work right, it still says im running 2.3.4 after it reboots. When I downloaded the SDK I had one thing that was unable to install(google APi's) when I updated.
(Downloading Google USB Driver package, revision 4
File not found: C:\Program Files (x86)\Android\android-sdk\temp\usb_driver_r04-windows.zip (Access is denied)
Should I have not updated? my file path for SDK as listed on top of SDK manager says C:\Program Files (X86)\Android\android\sdk I am unable to run sudo when i command adb shell, I get a $ and not a #. I'm also not too sure of what path to start with(the exact code) if I have to use the SDK path first. I am completely lost to how I am doing this wrong. I bet it is the stupidest thing that I am over looking or something. I'd really appreciate the help so I can get my phone rooted. Thanksss
