Root ADB Noob Question
tolu
So i recently changed my root from normal root without nand access to toast method since these newer roms require it.
Everything went well then i flashed fresh 0.3 then i updated the radio i noticed some apps i wanted were missing so i tried to follow flipz method which is :
Removed (copied to /sdcard/fresh-removed-apks):
The following applications have been removed, however I am trying something new. I have the installer copy all of these applications to /sdcard/fresh-removed-apks. This will allow you to easily install the applications by clicking on them in ES File Explorer, or by copying them to /system/app for the ones that won
