Root ADB not working??
mdonova33
When i go to push files to my phone, i type adb, and it says it is not a command!!
HELP ME!! IM LOSING MY MIND!!
when i go into cmd prompt and goto my tools folder and type adb shell
i get new line with
and it doesnt let me do anything else after that
That is the correct thing to be getting. You can't type anything from there?
i copy and past the lines to remove apps.. tried from 3 different sites (all have different lines for some reason)
and always says no such file or directory or whatever...
i actually got city id off somehow but none of the others like teeter and footprints...
gave up and moved on...
Some sites might be different because some delete the app off the phone using the rm command while others will move the app using the mv command to to move it to a folder that the phone won't look for installed apps.
Make sure that in ClockWorkMod /system is mounted. If it isn't mounted, your computer won't see it and will give you the error.
I keep getting this message when I run adb shell "adb is not recognized as an internal or external command operable program or batch file" can someone please tell me what i did wrong or what I need to do to get into adb shell
