Root ADB/odin help
Hello i forgot to sign my framework-res before i adb pushed it back to my admire and now im stuck in a Boot loop. So my question here is if im in ODIN download mode would i be able to push and pull files using ADB? :smokingsomb:
Depends on which rom your running my suggestion is to just uot a theme and flash it so It would overwrite the modified apk ...
Then from there sign the apk you have and push... lol that's what I do if I'm that situation ... if you can't get to recovery ... idk
did'nt work for me, i just re installed 2.3.6. ive learned my lesson to always take the time to make a backup
